Author Topic: Lube  (Read 903 times)
Offline Camstop
Lube
« on: September 28, 2004, 15:52 »
Hi guys  :waving:
I've been working with a digital hard disk multiplexer today and the fan in one of the hard drive caddies is making a bit too much noise.
My question is... What would be the best thing to lube the fan with and can i use something that i can get locally. The manufacturers mentioned a dry spray but didn't know what it was called  ::)
Re:Lube
« Reply #1 on: September 28, 2004, 17:17 »
Can't help you, Cammy, but the thread title had me worried!   :o ;D ;D
Re:Lube
« Reply #2 on: September 28, 2004, 17:43 »
Silicon Lube Cammy  ;)
I take it you have RS  ;) as your a mod Cammy fix the link  :P
www.rswww.com
* Simon fixed link.   :)
Offline Camstop
Re:Lube
« Reply #3 on: September 28, 2004, 19:43 »
Thanks for that Hook  :thumb:
I'm sure i have some silicon spray somewhere  ;)
