Author Topic: Events and Errors Message Center  (Read 2072 times)
« on: September 29, 2004, 00:29 »
Ok, here we go:
When you get an error number (code) on your system, do you understand what does it mean? Why? Where to go? How to solve the problem?
Well, here's a help place where you can go and check. It's made by Microsoft itself. Hope it'll be helpfull:
http://www.microsoft.com/technet/support/eventserrors.mspx
Find detailed explanations, recommended user actions, and links to additional support and resources.
New! We've added Event ID search capabilities at search.microsoft.com.
http://search.microsoft.com/search/search.aspx?st=b&View=en-us
Here's how it works: Enter '1001' (for example) or 'error 1001' and note that a relevant result appears as one of the top results overall and within the Support & Troubleshooting category. Each page referenced has an informative title, which includes the phrase "Events & Errors Help," followed by the product it applies to, the error source, and error number. When you click on an "Events & Errors" item in these Search results, it provides the error info we have on file, and it provides links to relevant Knowledge Base articles.
Or, if you prefer, use the links and examples below to search specific Events & Errors databases.
? Windows Server 2003
http://www.microsoft.com/technet/support/ee/search.aspx?DisplayName=Windows%20Server%202003&ProdName=Windows%20Operating%20System&MajorMinor=5.2&LCID=1033
To view Windows Server 2003 Events and Errors, type the Source (for example, Print) and/or the Event code (for example, 10) into the ID field, then click the Go button. Source and Event codes may be found in the Event Viewer logs.
? Windows XP Home/Professional
http://www.microsoft.com/technet/support/ee/search.aspx?DisplayName=Windows%20XP%20Professional&ProdName=Windows%20Operating%20System&MajorMinor=5.1&LCID=1033
To view Windows XP Events and Errors, type the Source (for example, Print) and/or the Event code (for example, 20) into the ID field, then click the Go button. Source and Event codes may be found in the Event Viewer logs.
? Windows 2000 Professional/Server
http://www.microsoft.com/technet/support/ee/search.aspx?DisplayName=Windows%202000%20Server&ProdName=Windows%20Operating%20System&MajorMinor=5.0&LCID=1033
To view Windows 2000 Events and Errors, type the Source (for example, Application Hang) and/or the Event code (for example, 1002) into the ID field, then click the Go button. Source and Event codes may be found in the Event Viewer logs.
Re:Events and Errors Message Center
« Reply #1 on: September 29, 2004, 08:08 »
That could be useful - nice one Joudi.   :)
