Author Topic: Compress your audio CD?s to MP3 using "Windows Media Pl  (Read 817 times)
If you have Windows Media Player 10 (WMP) installed on your system, you don?t need to install any other converting to MP3 program.
Open your ?WMP10? and right click on its? ?TitleBar?. Then Tools > Options, and open the tab ?Extract Music?. Scroll down the ?Format? part to select ?MP3? in that list. Slide the cursor to 192Kbit/s. You can modify there the destination folder too. Click OK, and close the Options window.
Now, put your CD in the drive, and open the ?Extract? tab (on the top). Check the desired songs to be converted into MP3. And click ?Extract the music?. It?ll then start converting.
To play it after that, you can use ?WMP? or ?Winamp? for example.
