Author Topic: 16 bit windows subsystem  (Read 1398 times)
Offline juedaz95
« on: October 05, 2004, 17:31 »
I've just had my pc reloaded. 2 of the games I used to play now get this message up so I can't install them:-[
the message is 16 bit windows subsystem
and it tells me that the system file is not suitable for running ms-dos and microsoft windows applications.
I really hope someone can help me. ???
Re:16 bit windows subsystem
« Reply #1 on: October 05, 2004, 18:09 »
Hi juedaz95 and :welcome:
Is it the same OS that you used to run them on before ?
If its a different one which OS were you using and which are you using now ?
Offline juedaz95
« Reply #2 on: October 06, 2004, 17:07 »
thanks for the welcome.i was and still am running windows xp home edition.
« Reply #3 on: October 06, 2004, 17:37 »
Can you open the directory where its installed to and right click on the games exe file, select properties and then change it to 95 or 98 compatibility mode  ???
« Reply #4 on: October 06, 2004, 17:45 »
Hi and  :welcome: to Pc-pals  juedaz95.
What games is it you're trying to load?
There are possibly 2 things that could be wrong.
Either you have files still on HD belonging to the first installation.  I would do a search and delete anything pertaining to the game.  Uninstall game and re-install and see if that works.
Set your color to 16bit and see if that makes a difference.
Come back and tell us how you get on.
PS  Also go to website of game and see if there are any patches needed to download.
Offline juedaz95
« Reply #5 on: October 06, 2004, 21:35 »
I've tried the compatibility mode but that doesn't help. then I tried changing the colour to 16 bit but that didn't work either.the game is alone in the dark {4?} the new nightmare and it used to work before I got my pc reloaded.I've never even heard of a 'subsystem'. ???
Offline Hiatus
    • JoshSalverda.com
« Reply #6 on: October 06, 2004, 22:28 »
Ha!
God, I hate that error! The problem is with the "autoexec.nt" file. It (somehow) disappears sometimes...
Try and d/l the file. Just search for it in google or something. Install/copy it to the "C:\Windows\system32" directory. If you can't find it I might be able to send it to you somehow.
Good luck!  ;D
l33t h@x0r... sort of...
Offline juedaz95
« Reply #7 on: October 09, 2004, 17:21 »
tried everything suggested to me, nothing worked. So I uninstalled service pack 2 and now my games work ;D. also my Power DVD had stopped working with service pack 2 and now it's working ok again ;D
« Reply #8 on: October 09, 2004, 20:54 »
now folks thats what a billion dollar service pack can do :-*
Offline Hiatus
    • JoshSalverda.com
« Reply #9 on: October 11, 2004, 19:51 »
Which games weren't working (if you don't mind me asking...?)
