Author Topic: Use MSN Messenger wherever you are  (Read 1161 times)
« on: October 06, 2004, 01:13 »
Are you away from home ?    Are you in your working place?    Are you in a friends place?    Are you in a Cyber Coffee?    Anywhere else?    MSN Messenger is not installed on that computer?    You feel the need to use it?    Well, no problem anymore. You don?t have to install it.    It?s too simple. Just visit this address and learn how:
http://webmessenger.msn.com/    Just sign in, and don?t forget to deactivate the ?Popup Blocker? of that computer.
Offline cerebus
« Reply #1 on: May 05, 2005, 19:17 »
easy enought to do although it seems tht my school has blocked access to tht site and many others too. :(
e're all cursed...   its called life.
Try the --==GTO==-- forums!! http://s9.invisionfree.com/GTO
