Author Topic: Fix Movie Interference in AVI Files  (Read 911 times)
« on: October 13, 2004, 03:05 »
If you have any AVI files that you saved in Windows 9x, which have interference when opened in Windows XP, there is an easy fix to get rid of the interference:
· Open Windows Movie Maker.
· Click View and then click Options.
· Click in the box to remove the check mark beside Automatically create clips.
· Now, import the movie file that has interference and drag it onto the timeline.
Then save the movie, and during the rerendering, the interference will be removed.
Sandra, I know that this is not exactly the problem of Aaron mentioned recently in:
http://pc-pals.com/index.php?board=27;action=display;threadid=13857
but seems to me, from far or near, somehow, as a little similar problem, which might be solved in this way. Isn't that worthy to be tried?
Re:Fix Movie Interference in AVI Files
« Reply #1 on: October 13, 2004, 12:37 »
Anything is worth trying Joudi, but I think movie maker would only workwith movie file extensions  :(
