Author Topic: Pop Up messages  (Read 1563 times)
Offline Serenity
Pop Up messages
« on: January 17, 2003, 19:21 »
I wonder if any of you guys can help with a few queries a girlfriend is having with her PC.  The following message boxes continuallu pop up on starting the PC :
1. Unhandled exception c0000005 at address :bff7a551
2. Pgmonitor. This has performed an illegal operation
3.Error starting program A required.DLL file, ICSAP132DLL, was not found
Any ideas are appreciated  :)
Offline Scrumpy-Jack
Re:Pop Up messages
« Reply #1 on: January 17, 2003, 20:04 »
Hi SERENITY   :)
These ERROR report messages would indicate that a program on you're computer is trying to access an external database program but can't due to a corruption of a DLL file.
An example of such a program would be a MULTIMEDIA program such as CROMPTOMS MULTIMEDIA ENCYCLOPEDIA or something similar.
I would suggest looking to see if any such programs are installed on the computer. If there ARE and you're friend wants to keep them. Then I suggest DELETING and then REINSTALLING such programs.
I hope this is of some help to you .  :D
Keep up the GOOD WORK  !
Cheers
Scrumpy-Jack    ;D
To do is to be." -- Socrates
"To be is to do." -- Sartre
"Do be do be do..." -- Sinatra
