Author Topic: How to Remote shutdown a Computer on  (Read 809 times)
« on: October 14, 2004, 04:10 »
1.    LAN/WAn
2.    Internet
They are both pretty simple and good fun, heres how
Righ click My Computer and select ?Manage?
The Following screen should appear, select the option form the actions menu, ?Connect to another computer?
Then Click ?Browse? Then Click ?Advanced? Then go to ?Find Now? And in the Box a list of all the computers on the network should come up. Click the one you want to shutdown then Ok All the boxes, Then Click Actions > Properties>Advanced>Start up and recovery settings>Shutdown, Then click Power down if supported, and Ok it, Watch your victim dissapear offline, Great if your losing at a LAN game or something similar.
How to shutdown a PC over the internet, Open up a dos window and type ?Shutdown -i? the following screen should appear and you can just put in your victims IP and include a shutdown message as well if you want. This has been disabled with sp1 because of several viruses that abused this feature.
