Author Topic: PDA Problem  (Read 2752 times)
PDA Problem
« on: October 15, 2004, 18:15 »
Hi all  ;D
Having problems Syncing my PDA to the new computer..its worked ok on my Ex works pc and my old PC at home? but the new one it doesn't want to know using the direct sync using Com1.
Have been to Palm website and gone through their help/trouble shooting guide and have come up against "is the IRQ assigned"..WTF? how do I know lol..anybody have any idea's
Hookstar
Offline Hiatus
    • JoshSalverda.com
Re:PDA Problem
« Reply #1 on: October 15, 2004, 18:42 »
Do you have to enable any ports in the BIOS?
I dunno.....stab in the dark.... :)
l33t h@x0r... sort of...
Re:PDA Problem
« Reply #2 on: October 15, 2004, 19:03 »
I have checked that Hiatus..but will double check later when I shut the puter down for a rest  ;)
Re:PDA Problem
« Reply #3 on: October 16, 2004, 07:55 »
Everything on that side of the Bios OK, looked in Everest Com1 shows up in there ok. Looked in WINMSD..IRQ shows up as no4 running ok.
Dont know what or where else to look
Re:PDA Problem
« Reply #4 on: October 16, 2004, 16:54 »
NE Body got any ideas.. been racking my brains for the last 3 hours, uninstalled reinstalled reebooted in both the logs it shows thay have made contact but no sync  :-\
Re:PDA Problem
« Reply #5 on: October 16, 2004, 17:56 »
Sorry Hookie, its not something I have ever played with, I think this is possibly a Dack or Sean jobbie  :(
Re:PDA Problem
« Reply #6 on: October 16, 2004, 18:08 »
The stoopid thing is Sandra? I have loaded it on 2 computers at work and 2 at home with no troubles what so ever..until I tried on this new computer.
This is the Log off the PC: The log file C:\Palm\Terryr\HotSync.Log cannot be found.
So it must have shook hands at some stage?
Re:PDA Problem
« Reply #7 on: October 16, 2004, 18:23 »
What about the Baud rate? might have a play with that  ;D
Re:PDA Problem
« Reply #8 on: October 16, 2004, 18:23 »
It's not your router firewall is it, Hook?
Re:PDA Problem
« Reply #9 on: October 16, 2004, 18:46 »
Wouldnt have thought so Simon, as its a local connection through Com 1 directly to my PDA..but you never Know  ::)
Re:PDA Problem
« Reply #10 on: October 16, 2004, 18:56 »
I think that Simons possibly pointed you in the right direction, but as he often does at work hes taken a wrong turn  ;)
You have SP2 on dont you Hookie ?
Maybe if you disable that and see if it allows it to synch and if it does then its just a case of configuring XPs built in firewall.
The firewall can block LANs via ethernet and USB so presumably it can do that on the COM ports too  :)
Re:PDA Problem
« Reply #11 on: October 16, 2004, 19:10 »
That was one of the things I had done this afternoon was to allow Hot sync manager to allow connection just in case  :D
Re:PDA Problem
« Reply #12 on: October 16, 2004, 19:16 »
:wahh:  :bart:
Re:PDA Problem
« Reply #13 on: October 16, 2004, 19:23 »
What model of PDA is it?
Reason I ask is there seems to be a problem with SP2 and the Hotsync software for some users over on the Pdastreet forums - affecting Sony Clie, Z1 etc.
http://www.pdastreet.com/forums/search.php?action=showresults&searchid=659926&sortby=lastpost&sortorder=descending
Seems to have occured mostly since SP2
Re:PDA Problem
« Reply #14 on: October 16, 2004, 19:28 »
Its a Palm m100
