Author Topic: Desparate TV card help needed  (Read 767 times)
Offline Jaminxz
« on: October 15, 2004, 20:49 »
argh!!! I am going insane trying to get my tv card working!!
I have a picture but no sound.I am not sure were to plug the sound wire in, can somebody help me??
I think i have tried everywere I can,so i'm thinking maybe a sound driver problem? or maybe my card can't use two sound devices at oncE? i don't know, help would be greatly appreciated.
thanks
Jaminxz
Re:Desparate TV card help needed
« Reply #1 on: October 15, 2004, 21:33 »
Can you tell us which tv card you are using  ???
« Reply #2 on: October 15, 2004, 23:26 »
"Out" from the TV card and "in" to the sound card  ;)
That was the problem I had..if not sorry  ;D
Offline Jaminxz
« Reply #3 on: October 17, 2004, 11:11 »
haha cheers guys,It was so simple!
I know the problem,when i plugged it into my sound card,I had it on mute accidently so i thought i needed to plug the wire into the speakers!!
pk thanks for your help guys.
