Author Topic: TFT monitors  (Read 2051 times)
Offline Jaminxz
TFT monitors
« on: October 17, 2004, 22:55 »
Hey guys,I'm in the market for a new tft, i'm looking at this one - http://www.dabs.com/uk/productView.htm?quicklinx=31V3
any comments??
cheers
jmainxz
Re:TFT monitors
« Reply #1 on: October 17, 2004, 23:04 »
Reasonable response time (14ms)
Doesn't say the colour palette (as if it's 16 bit then the response time suffers)
Reasonable contrast and luminance
Bad points:
Not multimedia
VGA connector only, no DVI
Good for the price - seems to be that 17" TFTs are finally coming back down to reasonable prices.
Re:TFT monitors
« Reply #2 on: October 17, 2004, 23:43 »
Hyundai L70S+..got this last week on special offer at Microdirect and just finished watching Van Helsing  ;D ...Must admit the screen res is very good with 12Ms refresh rate.
1 x 17" Hyundai L70S+ 12ms TFT Sil/Blk MultiMedia Monitor (3yrs onsite)  @ £189.99(223.24) each.
Viewable size as 19 inch CRT monitor
-17 Inch Viewable SXGA LCD
-High quality screen rescaling capability
-Real Color Fleshtone adjustment and digital color control
-with innovative color management
-A-Si TFT Active Matrix adopted
-0.264 mm pixel pitch
-1280 x 1024 @ 75 Hz Max. Resolution
-1280 x 1024 @ 60 Hz Recommended for use
-Advanced Digital On-Screen Display Controls
-Fast and Accurate Auto Adjustment
-Most Advanced Image Scaling
-Power Management
-TCO'03/99
-TCO 99 Certified
-Image Color Matching Profile
-Support VESA Flat Panel Monitor Physical Mounting Interface
-Audio System ; 2ch x 2w max
http://www.microdirect.co.uk/ProductInfo.aspx?ProductID=6674
Offline Camstop
Re:TFT monitors
« Reply #3 on: October 17, 2004, 23:44 »
This one seems popular...>>>here.
Scroll down for some customer opinions  :thumb:
