Author Topic: picture Viewer  (Read 759 times)
picture Viewer
« on: October 18, 2004, 01:57 »
· Pressing Ctrl-I in the picture viewer will bring up the property sheet for the image.  (doesn't work in slide show).
· Pressing DEL in the picture viewer will delete.
· Holding down the Ctrl key in the picture viewer enables "panning" (hand cursor)
