Author Topic: Create a Desktop Shortcut to Lock Your Computer  (Read 1749 times)
« on: October 19, 2004, 04:12 »
Ok guys, let's see if this function is the one which I was asking for, two days ago:
http://pc-pals.com/index.php?board=27;action=display;threadid=13939
Here it is:
You secure your computer by locking it whenever you're away from your desk. If you're on a domain, by pressing Ctrl+Alt+Del and then clicking Lock Computer, you can prevent unauthorized users from gaining access to your computer. Only you and members of the Administrators group on your computer can unlock it. (You unlock it by pressing Ctrl+Alt+Del, typing your password, and then clicking OK.)
To create an even quicker means of securing your computer, place a shortcut on your desktop to lock your computer:
? Right-click an open area of your desktop, point to New, and then click Shortcut.
? In the Location box, type:
%windir%\System32\rundll32.exe user32.dll,LockWorkStation
? Click Next, in the Name box type a name for the shortcut such as, Lock Computer, and then click Finish.
Here, I need your help:
When pressing Ctrl+Alt+Del, it didn't give me the option of "Lock Computer" anywhere. No place to make a "PassWord" neither. I even tried the "Lock" buttons of the keyboard, it didn't work.
Can you understand how to get that function?
Did I missunderstand something?
Re:Create a Desktop Shortcut to Lock Your Computer
« Reply #1 on: October 19, 2004, 16:20 »
You might be pleased to know, it didn't work for me either, Joudi.  No 'Lock Computer' option here either.  At least you know it's not you!   ;)
Offline Hiatus
    • JoshSalverda.com
« Reply #2 on: October 19, 2004, 17:13 »
You can hit "Windows Key + L" at the same time to go to the logon screen.
The shortcut you mentioned is just a longer way of doing this.
I don't know about the ctrl-alt-del thing...
l33t h@x0r... sort of...
Offline Flanjeuk
« Reply #3 on: October 21, 2004, 18:22 »
Locking is just the same as pressing "Switch User" (Start>Log Off>Switch User) - You are still logged in, just your on the log in screen... This only works in Windows XP (I think)
MD64 3500+ (Newcastle)
K8N Neo2 Platinum
Corsair XMS 512x2 Dual DDR
Western Digital 120GB IDE
Ebuyer Dracula Case
Saphire 9200SE (6800GT soon)
Logitech MX-510
500W PSU
« Reply #4 on: October 21, 2004, 21:57 »
Ok...In that case, if I'm making a download in my session, and I log to a different user, will the download continue in my principal (first) session?
« Reply #5 on: October 24, 2004, 00:40 »
Well joudi,
like I say to the Wife, when she asks " is the door locked"  I reply give it the ultimate test TRY TO OPEN IT  ;)
Offline cerebus
« Reply #6 on: May 05, 2005, 19:07 »
i think i know wot you mean about pressing ctrl + alt + del, as on the system we have in school it can be done an some ppl like to do it and leave the comp locked. i dont know how to get it on other systems though
e're all cursed...   its called life.
Try the --==GTO==-- forums!! http://s9.invisionfree.com/GTO
