Author Topic: WinME DLL Hell!  (Read 1723 times)
WinME DLL Hell!
« on: October 19, 2004, 19:57 »
A friend has a problem with a missing dll in Windows ME.  The DLL in question is powrprof.dll.  I have sent her a copy of it, and she has tried to put it in C:\Windows\System, but says she is still getting the same error message, saying the DLL is missing.
I understand there is no System File Checker in ME, and no 'Repair' installation option, so how does she go about replacing this DLL, without resorting to a full format and re-installation?
Offline Hiatus
    • JoshSalverda.com
Re:WinME DLL Hell!
« Reply #1 on: October 19, 2004, 20:12 »
Is the .dll supposed to go in the \system folder?
I'm guessing this is a laptop? powrprof.dll sounds like a program to monitor battery life or something.
The .dll might have to go into the program folder.
I dunno, worth a try.  :-\
l33t h@x0r... sort of...
Re:WinME DLL Hell!
« Reply #2 on: October 19, 2004, 20:14 »
I don't know if you've passed by. But probably this will give some light to the problem Simon:
http://support.microsoft.com/kb/q188213/
Offline Hiatus
    • JoshSalverda.com
Re:WinME DLL Hell!
« Reply #3 on: October 19, 2004, 20:25 »
oooo, PowerProfile.....I never thought of that,  ;D
Nice work joudi  :)
Re:WinME DLL Hell!
« Reply #4 on: October 19, 2004, 20:34 »
Thanks Joudi, but that relates to Win98.  ME doesn't have System File Checker (sfc.exe), so is it just a question of copying the file into the \system folder?  This is a desktop PC, not a laptop, and I spoke to another ME user last night, who confirmed that the powrprof.dll lived in the \system folder on her machine.
Offline Hiatus
    • JoshSalverda.com
Re:WinME DLL Hell!
« Reply #5 on: October 19, 2004, 21:19 »
Yup, ok, it's there. I checked my laptop.
Mine is 26kb if that matters. Also, it's supposed to load on startup.
I don't know if it matters whether or not it loads at startup if the file is corrupted. Usually it should though.
Re:WinME DLL Hell!
« Reply #6 on: October 19, 2004, 22:38 »
If you continue to have the problem, Simon, you could do a Run > MSCONFIG and remove the ticks from LoadPowerProfile from the startup items.  (It will probably appear twice.)
I have always stopped it from running on all my machines (as I don't like unnecessary programs loading at startup) without any problems whatsoever.  If I'm going to be away from the PC for a long time, and I can't be bothered to shut down, I simply hit the sleep key on my keyboard, and then the wake up key when I return.
Re:WinME DLL Hell!
« Reply #7 on: October 20, 2004, 00:48 »
That's worth considering, Dave.  I'm not even sure what LoadPowerProfile actually is.  Is it the same as Power Management in XP?
Re:WinME DLL Hell!
« Reply #8 on: October 20, 2004, 00:54 »
Like Dave, I stop load power profile at startup as well. Dunno what it does but somebody told me to untick it on startup folder as it's not needed at startup.
Re:WinME DLL Hell!
« Reply #9 on: October 20, 2004, 22:25 »
AFAIK, Simon, it is exactly the same.  I have read numerous articles advising stopping it as it is a resource guzzler.
Re:WinME DLL Hell!
« Reply #10 on: October 20, 2004, 23:52 »
Well, the bloody woman has now lost the dll I sent her, and has given up  ::) so it looks like I'll be getting the wretched thing to try to repair!  Do you think she'd notice if I accidentally put W2K on it instead?    ;D ;D
