Author Topic: Keep Your Favorite Programs Near the Top of the Start Menu  (Read 760 times)
Do you have a favorite application that you frequently use?
If so, you can elevate its' priority on the Start menu by putting it at the top of the list. This ensures that the program will remain on the Start menu and cannot be bumped by other programs, even if you use the others more frequently.
· Right-click the link to your favorite program on the Start menu and select " Pin to Start Menu ".
. To remove it from there, right-click it and select " unpin from the start menu "
