Author Topic: epox 8kta3  (Read 1289 times)
Offline jon996
epox 8kta3
« on: October 26, 2004, 15:06 »
hi all...
iv jus got a new mobo..well new to me and tis quite strange...on the mobo there are two little digital number thingys and they say FF?? wot does this mean?!
chars...jon ;)
rive it like you stole it!
Re:epox 8kta3
« Reply #1 on: October 26, 2004, 15:16 »
Jon.. I reckon if you look at the Manual or dload the manual if you havnt got 1? and a rough guess will be that it will be like the Bios beeps and if there is something wrong with the Mobo it will show up with a number fault  ;) I stand to be corrected as always  ;D
 ;D  ;D  ;D
The onboard P80P Debug Card provides very detailed POST debugging information via two hexadecimal LEDs. In fact, four pages of the manual are dedicated to the 50+ codes. I much prefer this type of debugging over both beep codes and voice-related debugging. Unlike the other methods which only provide error codes (the single post ?beep? notwithstanding), these LEDs monitor the status of the entire POST process.
Offline jon996
Re:epox 8kta3
« Reply #2 on: October 26, 2004, 15:19 »
thnk you very much hooky ;) :thumb:
Re:epox 8kta3
« Reply #3 on: October 26, 2004, 15:30 »
Lucky Guess I guess  ;D
Offline jon996
Re:epox 8kta3
« Reply #4 on: October 26, 2004, 16:26 »
jus one more thing...wot is a safe temperature for a 1.2 athlon?...
Re:epox 8kta3
« Reply #5 on: October 26, 2004, 17:26 »
Look here Jon
Offline jon996
Re:epox 8kta3
« Reply #6 on: October 26, 2004, 17:41 »
ahh thnk you nowonder you have a star in your name...
