Author Topic: FAT32 or NTFS?  (Read 1832 times)
Offline Flanjeuk
FAT32 or NTFS?
« on: October 26, 2004, 19:58 »
Which is better NTFS or FAT32, My current system is using NTFS, but I didn't set it up that way! What's the difference?
MD64 3500+ (Newcastle)
K8N Neo2 Platinum
Corsair XMS 512x2 Dual DDR
Western Digital 120GB IDE
Ebuyer Dracula Case
Saphire 9200SE (6800GT soon)
Logitech MX-510
500W PSU
Offline Hiatus
    • JoshSalverda.com
Re:FAT32 or NTFS?
« Reply #1 on: October 26, 2004, 20:19 »
Windows XP uses an NTFS partition. I don't know why actually...probably because it doesn't use MS DOS. All the older OS's use FAT32.
Someone here will know for sure what it all means...
l33t h@x0r... sort of...
Re:FAT32 or NTFS?
« Reply #2 on: October 26, 2004, 20:29 »
FAT32
- better for smaller drives (as cluster size starts getting very big - meaning you get situation where a 2 byte file takes up a 16k chunk of hard disc space
- no security so anyone with a boot floppy can read your files (unless extra software is installed)
- Max file size is about 4Gig
NTFS
- better for larger drives/partitions
- Has security capability in that you can restrict access to files/directories
- no max file size
However FAT32 easier to recover knackered file, as when NTFS goes......:)
Generally NTFS is better these days.
