Author Topic: asf files in powerdirector  (Read 1312 times)
Offline princeofdarkness
« on: October 28, 2004, 14:08 »
hi, i recently got power director 2.55 to edit skating footage but the program does not seem to work with asf files, i have tried using a convertor but it didnt work, and as the digital camcorder being used makes asf files it would be useful to be able to edit them... any suggestions?
thnx in advance Jonah
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
Re:asf files in powerdirector
« Reply #1 on: October 28, 2004, 15:31 »
I cant find which audio formats v2.55 supports but according to cynerlinks site V 3 supports asf.
Can you upgrade to V 3  ???
« Reply #2 on: October 28, 2004, 18:49 »
i cnt find a link to upgrade.. would i have to pay extra? thnx in advance
 jonah
Eyes of the dead
« Reply #3 on: October 28, 2004, 19:15 »
Jon ... try This to check if your AVF files are corrupt  ;)
« Reply #4 on: October 28, 2004, 19:46 »
i installed it but i cnt even find it... they aint corrupt i dnt think coz they play in media player n stuff they just cnt be edited in tht program.. what wud the best converter be?
thnx jonah
Eyes of the dead
« Reply #5 on: October 28, 2004, 20:10 »
Does it say which files your version supports in the help files ?
ASF has been around a while now so it possibly should accept them, if not you can see which format you need to convert to  :)
