Thanks Clive,
I have used mailwasher in the past - but found it annoying as I had more than one email account to "wash" and you had to run it before opening your email client.
I was looking for another application that sits in the system tray and gets on with its job quietly - but maybe I'll try mailwasher for a bit.
Do you recommend bouncing the spam using mailwasher? I heard that this just tells the spamers that you have an active address?
DJ
