April 08, 2025, 19:01
Technical Help & Discussion
Changing OS To Linux
Topic: Changing OS To Linux (Read 798 times)
Flanjeuk
Regular Member
October 30, 2004, 19:48 »
I was thinking,
As some of you may have read, I'm building a new system very soon...
What if I ONLY installed Linux?
I have never actually used it before but I have read that it is quite good...
What do you think?
MD64 3500+ (Newcastle)
K8N Neo2 Platinum
Corsair XMS 512x2 Dual DDR
Western Digital 120GB IDE
Ebuyer Dracula Case
Saphire 9200SE (6800GT soon)
Logitech MX-510
500W PSU
Dack
Established Member
Re:Changing OS To Linux
October 30, 2004, 21:22 »
It takes some getting used to but usually installs without any problems. To try and see if you would like it try downloading:
http://www.knopper.net/knoppix/index-en.html
It's a 'live' version of Linux that boots and runs from the CD - you don't even need to have a hard drive installed to run it. Check to see if it finds all the bits of hardware for your machine and see what you think of trying to run Linux only.
Flanjeuk
Regular Member
October 30, 2004, 23:05 »
Would that work on my existing system?
or does it only work when there isn't already an OS installed?
K8N Neo2 Platinum
Ebuyer Dracula Case
Logitech MX-510
500W PSU
Dack
Established Member
October 31, 2004, 00:05 »
Will work with your existing machine - it's a bootable CD but you can still acess your hard discs if they are there. As soon as you shutit down your machine is as it was before. Worth trying just to see WINE running Microsoft applications such as Word under Linux
