Author Topic: delete internet history  (Read 1303 times)
Offline Pwilsonscott
« on: October 31, 2004, 20:07 »
I am using AOL 9.0 Windows XP. Is there an easy way of removing internet addresses from the drop down menu marked hISTORY ? I have downloaded various free software to do with deleting history, and ran them, but the list of sites visited remains. Many thanks.
Re:delete internet history
« Reply #1 on: October 31, 2004, 20:26 »
I'm not sure I understand correctly what you are asking for. But till now I understand things in this way, where the answer is very simple:
Control Panel > InterNet Options > General (tab) > Clear History
Maybe you want to "delite Files" too.
« Reply #2 on: October 31, 2004, 21:07 »
Thanku. I have tried that, but the history still lists about 100 recently visited sites.
« Reply #3 on: October 31, 2004, 21:10 »
Have you tried AOL's own solution which can be found here:
http://help.channels.aol.com/article.adp?catId=4&sCId=402&sSCId=4027&articleId=218069
« Reply #4 on: October 31, 2004, 21:16 »
Thats cleared it. Thank you.
« Reply #5 on: October 31, 2004, 21:18 »
 :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
 :welldone: Clive, Sandra will be proud of you.  ;)
« Reply #6 on: October 31, 2004, 21:22 »
That will be a first!  ;D
« Reply #7 on: October 31, 2004, 23:33 »
As Andy Warhol once said "Everyone will be famous for 15 minutes sometime"  :)
Enjoy yours while it lasts Clive, and well done  :)
