Author Topic: Windows 98 - Internet Explorer  (Read 917 times)
Offline DJ
« on: November 01, 2004, 18:18 »
Hi :wave:
I have a PC thats running windows 98 (I know - but i can't change it due to it being a business PC).
Anyway I need to know what is the highest version of Internet Explorer I could use on it.
It is currently running IE5.00 - Could I go up to V6?
Also where can I download a copy of the older browsers from?
Thanks
DJ
Re:Windows 98 - Internet Explorer
« Reply #1 on: November 01, 2004, 18:35 »
I used to run IE6 on Win 98 so there is no problem with that.
You didn't specify which browsers you were referring to but you can get some dinosaurs from:
http://browsers.evolt.org/
and
http://www.skyzyx.com/downloads/
Offline DJ
« Reply #2 on: November 01, 2004, 19:21 »
Thanks Clive,
I was referring to IE.
I will try to install IE6 on the PC tomorrow.
DJ
« Reply #3 on: November 01, 2004, 20:44 »
Try www.oldversion.com DJ   :)
Old Versions Available
Internet Explorer 1.0 (1.1 MB)
Internet Explorer 2.0 (1.2 MB)
Internet Explorer 3.02 (Win95) (10.6 MB)
Internet Explorer 3.02 (WinNT) (8.7 MB)
You would probably have to get 5 and 5.5 off a 98 or 98se cd as I think those two versions were the ones that shipped with 98 and 98se originally. :doggie:
« Reply #4 on: November 01, 2004, 21:48 »
I wonder if IE1 would work on XP?   ;D ;D
