Author Topic: What Ram ?  (Read 865 times)
Offline kevinho
What Ram ?
« on: November 05, 2004, 08:45 »
Is there any way that i can confirm that the RAM in my pc is DDR 400?
Re:What Ram ?
« Reply #1 on: November 05, 2004, 09:31 »
Not easily (without opening the case).
You could always go into the BIOS and have a look, most, when set to auto detect, show the clock speed of the memory. However there may be an issue if the processor you are using is running of 333MHz as you then won't gain anything by running the memory at 400MHz and so it would default to 333. You should be able to set it manually to 400MHz and see if it runs.
Offline kevinho
Re:What Ram ?
« Reply #2 on: November 05, 2004, 16:40 »
Sorry maybe i was misunderstood. What i mean is how can i tell that the RAM in my pc is actually DDR 400 not DDR333. As i suspect that the RAM that was installed in my pc is only DDR 333 when i had paid for and requested DDR 400.
Below is what shows up in SiSoft Sandra
Memory Module(s)
Memory Module 1 : Nanya M2U51264DS88A1F-6K 512MB 8x(64Mx8) DDR-SDRAM PC2700U-2533-700 (CL2.5 up to 167MHz) (CL2 up to 133MHz)
Is this as i suspect DDR 333 and not DDR400 ? Is anyone able to tell from this or would more info be useful?
Thanks for your help (dont want to make a fool of myself if i am going back to complain Again!)
Re:What Ram ?
« Reply #3 on: November 05, 2004, 17:07 »
Hi there and welcome,
PC2700 is indeed the code for 333Mhz ram
Offline kevinho
Re:What Ram ?
« Reply #4 on: November 07, 2004, 10:33 »
Thank's for the confirmation.
Ah well back it goes again !
 :thanks:
