Author Topic: Dvd Codec  (Read 1494 times)
Offline renshaw8
Dvd Codec
« on: November 22, 2004, 08:26 »
I'm trying to get my dvd player to work on my Toshiba laptop and was told I need a WinDVD or PowerDVD codec. I was also told that I could download them at suprnova.org but when I went there the page was talking about Bit Torrents with a variety of differant options which I know nothing about. Can anyone help me understand this stuff. Thanks
f you watch the penny's, the dollars will watch themselfs.
Re:Dvd Codec
« Reply #1 on: November 22, 2004, 12:38 »
As Bit Torrents is a P2P type of file sharing I'm afraid that we cant really discuss too much about it other than to explain that the files in a "Torrent" are split into many bits and shared between users using a client program. Once a user has all the individual bits they are reassembled by the client program into the original file  :)
Re:Dvd Codec
« Reply #2 on: November 22, 2004, 16:33 »
I don't think there's any harm in saying that there is a free bit torrent client available here, which I am just about to try out for myself.  What we don't want to know, is what you use it for.  ;)
Re:Dvd Codec
« Reply #3 on: November 22, 2004, 16:39 »
Actually its not a windvd or powerdvd codec you need.
Windows media player should play dvds provided you have the correct codecs installed, which I think it has already. If you havent it should ask you to connect to the net and tell you which one you need.
Are these standard rented or bought DVDs ?
Offline renshaw8
Re:Dvd Codec
« Reply #4 on: November 22, 2004, 17:51 »
Thank you Sandra and Simon for your replies. I have a program called Interactual player that I guess is supposed to play my dvd's. I have a couple of dvd's and am planing on renting some also. When I tried to play one I bought, I got a message that said I needed a codec to play.
Re:Dvd Codec
« Reply #5 on: November 22, 2004, 19:24 »
Did it say which codec ?
You can often download individual ones free, just google for it  :)
Re:Dvd Codec
« Reply #6 on: November 23, 2004, 01:06 »
You need an MPEG2 Codec. These will be included in one of the DVD player softwares.
There are supposidly no free codecs as MPEG2 developers have to pay a license fee (about £8 per installation/distribution)
You might want to try and install:
http://www.free-codecs.com/download/Stinky_MPEG_2_Codec.htm though
(Failing that - http://www.free-codecs.com/download/Cole2k_Media_Codec_Pack.htm)
