Author Topic: Remote Servers  (Read 776 times)
Remote Servers
« on: November 30, 2004, 05:01 »
I just recently found the VNC remote server at
Code: [Select]
http://www.realvnc.com/<br />and it got me wondering about other types of remote servers. Once upon a time along while back i did experiment with PC anywhere, although i don't anymore because you need the software running on both the host and the control pc to use the prog. With VNC you can host a pc using its java interface. But i went looking for an even easier way and a came across references on google about something called RAT (Remote Access Trojan) which supposedly will let one control the infected users computer with almost absolute control. Allowing the victim to be used as a file dump and server for any online purpose.
heres a list of stuff sub will let you do.
4) The Features of SubSeven 2.1.5
            **) New Feature: under &quot;Local Options - Advanced&quot; section of the
            client theres a button &quot;Test on Local Machine&quot; which runs the server
            with special restrictions (accepts localhost connections only)
            1) Connection:
               A) IP Scanner - Scans for IPs with an open port you specify
               B) Get PC Info - All PC info, including Disk Size, Space, User etc
               C) Get Home Info - Gets all Home Info the vic specifies for their
                  Windows Registration ( not always availible)
               D) Server Options - Options pertaining to removing, changing port,
                  updating server, etc.
               E) IP Notify - Adds a new notify method or changes the current
                  method on the current server
            2) Keys/Messages:
               A) Keyboard - Open Keylogger, get offline keys, disable keyb. etc
               B) Chat - Chat with the Victim
               C) Matrix - Chat with the vic matrix style (black &amp; green design)
               D) Message Manager - Sends a popup message to the vic
               E) Spy - ICQ, AIM, MSN, YAHOO Instant Messenger Spies
               F) ICQ Takeover - displays all installed UINs on the pc, and u can
                  take each one over at the click of a button
            3) Advanced:
               A) FTP/HTTP - turns the vic into an FTP server, ready for files to
                  be downloaded via ur FTP client or browser
               B) Find Files - searches for a specified file type or file in the
                  vics pc
               C) Passwords - retrieves Cached, Recorded, RAS, and ICQ/AIM Passes
               D) RegEdit - Opens the vics Registry so u can f*** with it &gt;:)
               E) App Redirect - Lets you run a DOS command on the vic and shows
                  you the output
               F) Port Redirect - adds an open port to the vic so you can &quot;bounce&quot;
                  from it using the vics host as your own, E.G.: proxy type of
                  contraption via IRC
            4) Miscellaneous:
               A) File Manager - Upload, Download, Run, and do alotta other cool
                  s**t via this client
               B) Windows Manager - Displays open windows which you can close,
                  disable, etc.
               C) Process Manager - Shows all processes you can kill, disable,
                  prioritize etc.
               D) Text-2-Speech - Messes with the Text2Speech engine on the vics
                  pc, you type, it talks
               E) Clipboard Manager - View, change, empty the vics clipboard
               F) IRC Bot - Connects an IRC bot from the vic to an IRC server of
                  choice
            5) Fun Manager:
               A) Desktop/Webcam - Views Webcam continuous capture, a desktop
                  continuous preview and full screen capture
               B) Flip Screen - Flips victims screen upside down, and sideways
               C) Print - Prints on victims screen
               D) Browser - Opens victims browser with the webpage you specify
               E) Resolution - Changes victims pc resolution
               F) Win Colors - Changes the victims computer colors
            6) Extra Fun:
               A) Screen Saver - Changes the Vics Screensaver
               B) Restart Win - Shuts down, reboots, or logs off the victim
               C) Mouse - Set Mouse trails, reverse buttons, hide curson etc
               D) Sound - Record from vics mic, change volume settings
               E) Time/Date - Changes system time
               F) Extra - A whole buncha extra s**t like hide desktop, hide start
                  button, hide taskbar, open cd-rom etc.
            7) Local Options:
               A) Quality - Adjusts the quality of the Webcam/Desktop
               B) Local Folder - Changes the Sub7 Local Folder
               C) Skins - Skin manager for Sub7
               D) Misc Options - Misc s**t like toggling animation of windows etc
               E) Advanced - Messes with ports used for some Sub7 Functions Dont
                  bother messing around
               F) Run EditServer - Hmm..i wonder what this does...
Now despite this being a virus. It sure has more options than any peice of remote software ive seen thus far.
Here comes the question. Is there a legit peice of software that will accomplish as much or near as much as a RAT? I mean damn its even got FTP and HTTP capabilities.
Offline Hiatus
    • JoshSalverda.com
Re:Remote Servers
« Reply #1 on: November 30, 2004, 21:21 »
Um...not that I've found...subseven gets picked up be AVG quite quickly and isn't that great nemore.
Neways, yeah...VNC was what I used b4, but now I have XP Pro so I don't need to use that nemore. I haven't really been looking for anything you've described...if I come across anything I'll let you know...or vice versa, possibly if u find anything. ;D
l33t h@x0r... sort of...
