Author Topic: Kodak dx3500 digital camera  (Read 2383 times)
« on: December 02, 2004, 18:35 »
I have a Kodak digital camera with dock which transfers pictures automatically to PC.
When I upgraded to XP my software no longer worked.  I downloaded the update for XP. It installed ok but PC won't recognise camera.
I have been trying to solve this problem since 2pm today and I am back at square one.
How I hate XP :horror:
Re:Kodak dx3500 digital camera
« Reply #1 on: December 02, 2004, 19:23 »
I use a Fujifilm digital camera Lona and to the best of my knowledge I don't have any dedicated drivers or software for it.  When I plug it in and switch on I get a Windows XP screen saying "removable disk drive F" and a set of options asking me what I want to do with the photos.  I'm pretty certain that this is all built in to XP and it's ridiculously easy to use.
« Reply #2 on: December 02, 2004, 19:46 »
I think that's a frequent problem with XP and the digital cameras softwares, Lona.
Have you tried to, just uninstall the camera sofrtware, and then directly you plug it in (without its' software, of course)?
« Reply #3 on: December 02, 2004, 21:20 »
I've tried that Joudi but it still didn't find camera. I will uninstall the software one more time and try it again. :)
« Reply #4 on: December 02, 2004, 22:25 »
Try it in a different USB, Lona.   :)
« Reply #5 on: December 02, 2004, 23:23 »
Tried everything.  Uninstalled the software and unplugged camera, rebooted and plugged in the camera. No window popped up as Clive mentioned.
This camera is one of these docking ones and you need the software to make it work. I have been in Kodak's site and the software I downloaded was for XP service pack 1, they don't seem to have service pack 2.
I wish Tony would come on so as I can tell the *hit this operating system is causing me.  I never had as much hassle with WinME. :(
« Reply #6 on: December 02, 2004, 23:29 »
My camera lead plugs into a USB port Lona.  I also use the same lead with another Fujifilm camera and that works just the same.  No drivers, no software no nothing.  XP somehow just makes it work.
« Reply #7 on: December 02, 2004, 23:33 »
As above.  I have never used the Kodak software, or the docking unit.  I just plug the camera into a USB port, and load the pictures into Windows Picture Viewer.
« Reply #8 on: December 02, 2004, 23:39 »
Until they bring a fix out for SP2 Lona why dont you just upload to your ME pc and then transfer the photos over your LAN to your XP pc  :)
« Reply #9 on: December 02, 2004, 23:46 »
I thought of that Sandra, but Niall has enough cables and not much room. If I'm stumped I will have to do that but you would have thought the camera would have worked on this machine.
http://www.kodak.com/global/en/service/downloads/dln_ekn.jhtml?ekn=EKN009394
That's what I downloaded and it installs ok but won't find camera when I plug it in. ???
« Reply #10 on: December 02, 2004, 23:51 »
Have you tried this from that sites FAQs for exactly your symptons Lona  ???
http://www.kodak.com/global/en/service/knowledgebase/dx3500-faqs.jhtml?pq-path=10/3905/3921/750/907
The next to the bottom link :
My Kodak digital camera will not connect to my computer running the Windows XP operating system although it previously worked with that operating system. What is wrong and how can I fix it?
The problem may be with your Windows XP operating ...
« Reply #11 on: December 02, 2004, 23:55 »
Sorry Lona for my too simple (maybe stupid) question. But I ask it, just in case:
When you plug it in, do you switch your camera on?
Seems to me as if there's no power in the camera. maybe worthy to try that side of the matter.
Sorry again...
« Reply #12 on: December 03, 2004, 00:16 »
Yes my camera is switched on Joudi.  :)
Sandra, was already in that knowledge base and all my usb ports are enabled. :)
« Reply #13 on: December 03, 2004, 00:22 »
It wasnt the enabled bit it was this bit Lona :
Click Properties. The USB Root Hub Properties window displays.
Click the Power Management tab.
Uncheck the Allow the computer to turn off this device to save power box. (This will prevent a power loss to the USB port.)
« Reply #14 on: December 03, 2004, 02:25 »
:-[ I am so embarressed to admit it was the usb cable at the camera end that wasn't properly in that was causing pc not to find it.  :doh:
