My suggestion would be to ignore the patch for now. If there's a problem with it, MS will no doubt soon find out and fix it and issue another.
I haven't noticed the update myself, but XP does it automatically anyway. Actually, that's a point - is the update for your OS? Some of them are specifically for XP, and if you haven't got XP, it probably won't work!
