Author Topic: More useful computer tools  (Read 759 times)
« on: December 28, 2004, 11:32 »
www.blackviper.com/WinXp/servicecfg.htm     windowsXP startup speedup.
www.sof32.com/download-BootVis.19687-5.html    find XP startup hangups.
http://oca.microsoft.com/en/windiag.asp  random crash diagnosis tool
www.nu2.nu/pebuilder if Xp won't load . create a bootable CD.
once downloaded and unzipped into a folder called pcbackup, next copy all the files from from your installation CD into the folder on your hard disk apply SP2 to these files by typing  id:\xpsp2_en_x86.exe -s c:\pcbackup
now run pebuilder.exe and enter c:\pcbackup, this builds an ISO image that you can burn to a CD-R.
check for corrupted system files and fix them
START,RUN,SCF/SCANNOW
check for hijacked browsers www.definitivesolutions.com/bhodemon.htm
Convert AVI/MPG to DVD quality files www.videohelp.com use TMPEG Encoder to convert files to MPEG PAL Layer 2 format then use TMPEGenc DVD Author to create chapter  menu's etc, and create the VOB's from the MPEG files created in step 1 finally burn the VOB's to a DVD with nero.
