April 07, 2025, 17:58
Technical Help & Discussion
msdos window popped up
Topic: msdos window popped up (Read 786 times)
whathaveidone
New Registration
January 03, 2005, 12:03 »
I just connected to the Internet and my pc was unusually slow.Then a msdos window popped up and the only thing i could read before it closed again was 'deleting windows ServeID'
What happened and why did it happened?
Re:msdos window popped up
January 03, 2005, 12:51 »
Hopefully you will have an up to date antivirus program installed so it would be a good idea to run that to see if you have picked up a virus.
Secondly, download (also check for updates) and run Ad-Aware SE from
http://www.lavasoftusa.com/software/adaware/
Let us know how you get on with that. Good luck!
January 03, 2005, 18:47 »
You could also download and run
Spybot S&D
, which can find different things to Ad Aware. It's often a good idea to run both. As Clive said, let us know how you get on.
