Author Topic: guessing this is a software problem  (Read 1176 times)
Offline twiggy
« on: January 04, 2005, 15:04 »
Yesterday this window pop-up totaly out of no where.
Now when you press either button it closes and cumes back again stright away you can't do aything with out it poping-up and being there, its there now as i type this messege.
 :-\any ideas?
Re:guessing this is a software problem
« Reply #1 on: January 04, 2005, 15:54 »
You havent installed any old DOS based games or programs have you Mark  ???
Offline twiggy
« Reply #2 on: January 04, 2005, 17:36 »
Nope not that i no of ???
Offline twiggy
« Reply #3 on: January 05, 2005, 13:15 »
You reckon a system restore will do it? But if you're thinking its a software problem it wont work will it?
« Reply #4 on: January 05, 2005, 13:22 »
It should work if its a software problem but not if its hardware Mark.
Sorry I havent had time to see if I could find anything about it yet so a restore may be worth trying  :)
« Reply #5 on: January 05, 2005, 17:41 »
Just as a precaution, can I suggest a complete virus scan, plus Ad Aware and Spybot scans to see what shows up?  Maybe something is trying to lauch, that shouldn't be?
« Reply #6 on: January 05, 2005, 18:26 »
My other half, who's totally computer illiterate, was telling me earlier that some of his colleagues at work had also experienced this problem.  They were certain it was a virus that the AV companies hadn't yet managed to get to grips with  :(.
Sorry to be so vague but I thought it worth mentioning.
Gill
Offline HeddaLora
« Reply #7 on: January 13, 2005, 22:03 »
Sounds a whole lot like adware. I agree with previous recommendations. Here are some links:
-- Download AdAware, check for updates, run it and remove whatever it finds
-- Download, update and turn on SpywareBlaster and SpywareGuard.
« Reply #8 on: January 13, 2005, 22:57 »
...not to mention Spybot Search & Destroy.   ;)
