Simon may be right regards reinstalling....if he actually means "restoring" using XP Restore. I tried a restore and it would not have it. I then put the ID's back to what they were before I enabled continious randomisation in ID Blaster. And it still failed to do a restore.
I then left the ID's in their original state, kept ID Blaster disabled, disabled /re enabled restore, then at a later time attempted a restore, it worked.
Now I may in the future test XP restore prior to enabling ID Blaster, and trying restore again. Then again, I'm getting bored with it, so i may not
I just looooooove having a saved image of my C;Drive .......it allows you to muck about with the OS and all the settings ....and if you cock up big style ....you just re-image C;Drive
