Author Topic: Proving your on IPStream  (Read 1302 times)
Offline Bryon
« on: January 10, 2005, 13:45 »
Hello there.
I read somewhere, can't remember where, that there is a BT login test of some kind that if valid, proves you are on IPStream ADSL and not Datastream.  Anyone know where that is?
I believe you don't have to be an ADSL user at BT to use this.
Thank you,
Bryon.
Offline Bryon
Re:Proving your on IPStream
« Reply #1 on: January 10, 2005, 15:39 »
I have found the answer while browsing:
http://www.kitz.co.uk/adsl/speeds.htm
Just in case anyone doesn't know (was it only me ;D), according to this guide, this BT test proves your on IPStream.
Bryon.
« Reply #2 on: January 10, 2005, 15:47 »
Thanks for that Byron and :welcome:
Sorry that you had to find the answer yourself  :-[
Offline Bryon
« Reply #3 on: January 10, 2005, 15:54 »
That's ok  :). It was not long after my question that I found the answer so I wouldn't have expected any replies.
Thanks for the welcome.  If I think of anything else I won't hesitate to post again.  ;D
Cheers,
Bryon.
