Author Topic: Outlook Express attachments  (Read 2386 times)
« on: January 21, 2003, 23:01 »
I've just received e-mails with attachments from two friends, both of which are jokes and probably suitable for the forum.  Although it says the attachments are there, and gives the file size, when I click on them to open them they are greyed out.  The one e-mail is a second attempt so I wonder if its something wrong with my mail setup?  I am fairly confident that they have been sent to me correctly.
Re:Outlook Express attachments
« Reply #1 on: January 21, 2003, 23:06 »
Try saving the attachment into Word or some other folder and see if it opens from there Clive. This has happened to me but when I saved it to another folder the attachment opened. :)
« Reply #2 on: January 21, 2003, 23:09 »
I think it wil be your security settings in OE Clive.I use Incredimail but sometimes mail comes with an OE attachment and does a similar thing :(
« Reply #3 on: January 21, 2003, 23:28 »
Thanks for putting me on the right track.  It was indeed my security settings in OE and I've disabled them so I can now open the attachments.  Oh, they are good!  I hope I can upload some of them.
« Reply #4 on: January 22, 2003, 16:10 »
I presume they are clean ones Clive ;D ;D ;D
« Reply #5 on: January 22, 2003, 16:33 »
They are the new ones I posted in the DZ.   :heehee:
Offline DualBoy
    • http://www.pingme.ca
« Reply #6 on: January 23, 2003, 05:02 »
Steps to fix this problem:
Open Outlook -> Goto Tools -> Options -> Security Tab -> Uncheck the "Do not allow attachments to be saved or opened that could potentially be a virus" box then click okay and close Outlook express. Then restart outlook express and all fixed.
