Author Topic: installing one copy of windows on multiple pcs...  (Read 1046 times)
Offline goteamben
« on: January 14, 2005, 22:17 »
Hiya
Just wondering if it;s okay to install one copy of windows XP on more than one pc?  it probably isnt is it :S?
Thanks
Re:installing one copy of windows on multiple pcs...
« Reply #1 on: January 14, 2005, 22:28 »
By doing so, you will incur the wrath of Misrocoft - who will send people round to your house to tie your shoelaces together.  You have been warned.   8)
« Reply #2 on: January 14, 2005, 23:01 »
I believe that you can after 6 months as its reasonable to have upgraded your pc in that time, but dont blame me if what I have heard is incorrect on this one  :)
Offline goteamben
« Reply #3 on: January 14, 2005, 23:14 »
So if i do decide to install it, it would probably be best to invest in velcro shoes?  :)
thanks for the help guys
« Reply #4 on: January 14, 2005, 23:39 »
Knowing how Micro$haft can so easily snoop into your doings, even if you did install XP on another machine (and I believe Sandra is correct in the 6 months thing, as I did it on my own), I wouldn't put it past them to be able to see that two machines are running on the same licence.  :naughty:  ;)
« Reply #5 on: January 14, 2005, 23:49 »
Even if Microshaft can, in theory, tell if you are running the same licence on more than one machine, with their track record it probably doesn't work properly, so I wouldn't worry about it.
« Reply #6 on: January 15, 2005, 15:44 »
It works as long as you dont put it on all machines at the same time.
and you cant report any errors or they can trace it back
