Author Topic: All games crash  (Read 983 times)
Offline MADASAHATTER
All games crash
« on: January 17, 2005, 19:50 »
Hi all :)
  The problem is this . Every game i install and try to play just freezes...eg HL2,DE2.LOTR BFME causes a serious crash , shows the blue screen ,"summin about nvdisp " and reboots. Everything was working fine on my old SOLTEK mobo untill it fried.
 My new board is the GIGABYTE GA-7VAX , ATHLON2100+ , Creative Geforce4600ti , Audigy Platinum , 2*512 DDR PC2100`s , WinXP SP1 ( and the problems happened in SP2 ) and all the latest drivers.
Monitor is HANSOL710P 1024*768 @ 100HZ.
Freecom DVD+RW.
All or any help will be greatly appriciated
Cheers
Carl
Offline Camstop
Re:All games crash
« Reply #1 on: January 17, 2005, 20:46 »
Hi Mad and  :welcome:
It does sound very much like a graphics card driver fault and i had a problem with mine when i went to SP2 as well  ::)...
I updated to the latest driver for my card and it wasn't very stable so i installed the previous latest one and it's been a lot better  :thumb:
I'd suggest trying the previous latest driver for your graphics card as the latest one can sometimes have problems with them until they've been well tested  ;)
If that doesn't help any I'm sure there will be other ideas from more techie people later  ;) ;D
Re:All games crash
« Reply #2 on: January 17, 2005, 20:49 »
Cheers for your help :)
Tried that with no success:( but thanks anyways.
(<<<Sits waitin for more answers)
Re:All games crash
« Reply #3 on: January 17, 2005, 20:53 »
The problem first started when STEAM updated HL2, but i`ve recently formatted ( no HL2 installed ) and still get the damn (worse than b4 )problem.
Sorry just remembered i flashed the bios the other day, everything when fine so i dont think its that .
Could it be anything to do with VIA chipset?
Re:All games crash
« Reply #4 on: January 17, 2005, 21:06 »
You could try the latest mobo drivers from :
www.viaarena.com
Re:All games crash
« Reply #5 on: January 17, 2005, 21:07 »
Did the games crash before you flashed the bios ?
Did you save the old bios ?
If it didnt crash before then flash back to the old bios maybe  ???
Re:All games crash
« Reply #6 on: January 17, 2005, 21:19 »
Did`nt have any games installed before i flashed. I obtained the mobo from my brother and it did`nt recognise my 2100+ , it said it was a 1500+ so i just flashed .
And no i dint save ??? my BIOS. :'(
