Author Topic: Sony Sonicstage  (Read 836 times)
Offline nilsatis
Sony Sonicstage
« on: January 22, 2005, 14:43 »
Hi all,
       I have installed sony's sonicstage, but when I try and record from it onto disc or midi disc, it says that device is not connected, I have looked for the device in hardware, but it does not have a other devices section so I cannot find it, any ideas???
Re:Sony Sonicstage
« Reply #1 on: January 22, 2005, 17:44 »
I assume that it connects via USB ?
Have you tried reinstalling it ?
Offline nilsatis
Re:Sony Sonicstage
« Reply #2 on: January 24, 2005, 14:15 »
Sandra, Yes it does connect via usb but for some reason its not working, I have tried re installing but there is no difference.
Re:Sony Sonicstage
« Reply #3 on: January 24, 2005, 14:23 »
Is this the first time you have tried it or have you had it installed previously on another pc ?
Have you got the latest drivers and software from the sony site or are you using the cd that came with it  ???
Which OS are you using and do the usb ports that you have tried it in work ok with other usb stuff ?
