Author Topic: dvi differances?  (Read 833 times)
Offline measter
dvi differances?
« on: January 23, 2005, 19:03 »
i've recently looked into buying a second moniter for my pc, and have been looking for dvi-i to vga adaptors(my graphics card has both a dvi-i and vga socket), and needless to say, i've not found one in england yet. but a week or so ago i got a hyundia Q17+, which has a dvi-d socket on the back. i wanted to know what the differance between the dvi types were, and if it was possible to connect a dvi-i to dvi-d without the need for an adaptor.
Current CPU Info
Re:dvi differances?
« Reply #1 on: January 24, 2005, 19:24 »
http://support.dell.com/support/topics/global.aspx/support/kb/en/document?dn=1062206&c=us&l=en&s=dhs&cs=19
Should help you out :)
Basically -D = digital only, -I = integrated (Digital and Analog signals)
DVI to VGA adaptors are quite easy to find - about £2.50 plus vat plus delivery from a local supplier.
Offline measter
Re:dvi differances?
« Reply #2 on: January 25, 2005, 02:37 »
brilliant! thanks dack. ;D
Current CPU Info
