Author Topic: encoding mp3s  (Read 781 times)
Offline jon996
encoding mp3s
« on: January 24, 2005, 16:46 »
hey all
i have a song that plays at 80kbps and its bad quality
is there any way to re-code it to 192kbps?
>>jon
rive it like you stole it!
Re:encoding mp3s
« Reply #1 on: January 24, 2005, 19:03 »
MP3 uses a lossy compression - in other words the missing bits of data are lost forever so you can't get back any data thats not there. Re-encoding would just give the same signal quality as the original.
