Author Topic: Digital camera connection lead  (Read 2061 times)
« on: January 25, 2005, 10:13 »
Santa very kindly bought me a Fuji A330 digital camera for Christmas.  Unfortunately, I've misplaced the usb connection lead :( .
I was thinking of buying a replacement but they seem to be so expensive - about £25.00!  Does anyone know where I might be able to get one for less than this?  Would it be better for me to get a card reader instead?
Gill
Re:Digital camera connection lead
« Reply #1 on: January 25, 2005, 11:42 »
A card reader would probably be a more practical solution Gill.
Is the camera connection the very small plug and not the size you get with modems and other usb stuff ?
« Reply #2 on: January 25, 2005, 15:11 »
That is indeed the case, Sandra.
While I was out shopping this afternoon I noticed a new computer shop had opened in the high street.  Unable to restrain myself, I popped inside and started chatting with the owner while he was opening some fresh stock deliveries.  As luck would have it, one of the items he picked up was a card reader :).
Problem solved :)!
Gill
« Reply #3 on: January 26, 2005, 11:25 »
I've just found the lost lead.
Grrrrrrrr.......
 :curse: :curse:
« Reply #4 on: January 26, 2005, 13:23 »
A card readers never lost Gill  :)
Just think you wouldnt have had the luxury of a card reader if you hadnt mislaid the lead in the first place  ;)
It will be interesting to see which one transfers the pictures to the pc the fastest although if its a usb connected card reader then there probably wont be much in it  :)
