Author Topic: Router and x box live  (Read 750 times)
Offline speaseski
  • New Registration
« on: January 29, 2005, 14:46 »
Hello. How is everyone? This is my first time here. Here is my problem. I have a Linksys wireless broadband router. I have my one computer and X box wired to ports 1 & 2. I also have a computer in another room that is wireless. When my son is on x box live, I cannot get on line with my wired computer.It starts to load but it does'nt get there. Any ideas on this? Thank you.
Re:Router and x box live
« Reply #1 on: January 29, 2005, 15:00 »
Hi Speaseski and :welcome:
Does your wired pc go on line ok if the X box is off line ?
It sounds as if the router isnt assigning an IP address properly to your pc for some reason.
Have you checked that its assigned an IP in the range that the router operates in and not just the default LAN one ?
To check this go into Network Conections and see if it says IP assigned by DHCP or something else.
Offline speaseski
  • New Registration
« Reply #2 on: January 29, 2005, 15:40 »
Hello. My wired computer works fine otherwise. I went into the network connections . Everything I see means nothing to me I did not see anyhting worded like you said. I think I'm in over my head. Thank you very much. Dave.
