Author Topic: Windows 2000 won't boot  (Read 1111 times)
Offline zephra
« on: January 29, 2005, 20:22 »
Hi,newbie here could someone please help..???I wanted to d/l adaware and update Windows.My sister was logged in as a administrator and the computer was on.I did not have her password so I set the other users as administrator and I changed all the passwords.( I did this because i would need to reboot).I downloaded adaware and adaware would not install automaticly so I looked for the download in the search bar/start menu.All of a sudden I get a windows is preparing to install and the computer reboots on its own.Upon loading windows it stays in prepare security policy for 20 minutes.I am able to start in safe mode ok.What should I do next.I would not be surprised if she has a virus
Thanks
Offline zephra
Re:Windows 2000 won't boot
« Reply #1 on: January 29, 2005, 20:36 »
I have tried to boot windows to last known config and i still have this freeze in normal boot.
I have went into device manager and looked for conflicts found a scanner error which i fixed.I then Rebooted in normal mode and still have windows is loading security policies freeze.
Offline zephra
« Reply #2 on: January 29, 2005, 21:08 »
I just went into safe mode under device manager to shut off devices to see if there is a problem i shut off ethernet cards,sound,com ports cd-dvd rom drives and floppy drive.now i cannot start at all i get a 02b0 diskette drive a error.what can i do???
« Reply #3 on: January 30, 2005, 00:04 »
I think with your last post that its trying to boot off a disabled floppy drive.
Try going into bios and setting it to boot from the hard drive as the first device.
As far as the other things go I cant really think what to suggest other than if you are running XP to try Start/Run and tpe sfc /scannow and see if it will repair itself  ???
Offline zephra
« Reply #4 on: January 30, 2005, 16:53 »
How do I do that?
I have boot time diag.Disabled
Floppy Check Disabled
1Removable Devices
2Atapi CDRom Drive
3Hard Drive
4Network Boot.
Should I change any of these??
Offline zephra
« Reply #5 on: January 30, 2005, 17:05 »
Moved Hard Drive to number 1.Still have same error.I should have never  disabled  Floppy drives under device manager
Offline zephra
« Reply #6 on: January 30, 2005, 19:56 »
Thanks sandra!!!!Windows 2000pro I was able to boot back up after resetting Bios to default.I can still only boot in safe mode.
« Reply #7 on: January 30, 2005, 21:32 »
I think 2K has a system file checker in too so you could try what I suggested when I thought that you were using XP.
Start/Run and tpe sfc /scannow and see if it will repair itself.
The command maybe sfc.exe in 2k if the first one doesnt do anything, it should work in safe mode I think  :)
