Author Topic: Can't copy an audio disc successfully  (Read 748 times)
Offline Saddler
« on: February 04, 2005, 08:23 »
I have a Toshiba satellite A-130 using XP Home and SP2, I'm running an up to date version of Nero(6.??)but am unable to burn a complete copy successfully. I've tried slowing the write speed to 4X, it goes further, but does not finish the disc. I've used the same brand successfully before(on a different PC). Any suggestions or is this SP2 playing up again!!
Thanks
n the realm of the blind the one-eyed man is king
Re:Can't copy an audio disc successfully
« Reply #1 on: February 04, 2005, 12:55 »
Have you burned that make of disc successfully before  ???
SP2 does seem to have problems with Nero 6, I have not been able to erase DVD RWs since having SP2 on even though I have now got the latest version of Nero and the latest updates  :(
« Reply #2 on: February 04, 2005, 14:57 »
Are you trying to burn disc to disc?.  If so I would try copying original disc to hard drive and try burning it from there. :)
« Reply #3 on: February 04, 2005, 18:00 »
Is the source disc copy protected?   :-\
Offline Saddler
« Reply #4 on: February 08, 2005, 10:15 »
IN reply to the last three replies, thanks.
1)I have burned this brand successsfully previously.
2)I 'm not copying disc to disc as I only have one drive.
3)My mate has SP2 and Nero works for him
4)Source disc is copyrighted, this may be a problem, I'll try another source disc.
