July 03, 2024, 07:55
Technical Help & Discussion
dvd drive
Topic: dvd drive (Read 812 times)
postman4772
New Registration
dvd drive
February 06, 2005, 17:53 »
Just tried to play a dvd,havent played 1 on this laptop since re booting with xp..using media player 10..it says: CODD116A UNABLE TO PLAY DVD YOU MUST HAVE A DVD DRIVE AND DVD DRIVE SOFTWARE?
?ANY IDEAS THANX
joudi
Established Member
Re:dvd drive
February 06, 2005, 18:01 »
Hi postman4772 and
If it tells you that: Is your drive a DVD drive, or only CD grive?
If it's only a CD drive, that message is very normal.
Also, even if it's a DVD drive, your laptop needs naturally a DVD player software to be able to play the DVD.
http://www.gocyberlink.com/multi/products/product_main.jsp?ProdId=1
http://www.allianceweb.sk/free-download/windvd.php
http://www.blackmaxpc.com/Reviews/WinDVD.htm
postman4772
New Registration
Re:dvd drive
February 06, 2005, 18:08 »
ITS A DVD DRIVE,IT DID WORK ON MY OTHER LAPTOP....WHERE CAN I GET THE SOFTWARE FOR IT??
joudi
Established Member
Re:dvd drive
February 06, 2005, 18:29 »
Oh Sorry !!!
Seems you gave your answer while I was making the modification.
Ok now, You can have a look again at my first post and get the sites addresses.
dvd drive
