Author Topic: si soft sandra (standard)  (Read 1425 times)
Offline cabra
« on: February 15, 2005, 12:13 »
i get the following error when trying to run sandra.
"a device attached to the system is not functioning."
the msimg32.dll file is linked to missing export gdi32.dll:gdigradientfill.
i have no idea what this means,i have a file msimg32.dll and also gdi32.dll.
other than that i dont no what needs to be fixed. any help please? :cry:
« Reply #1 on: February 15, 2005, 12:56 »
:welcome: cabra.
Which version of Sandra are you using?  Also, which operating system are you using?  I had a similar problem with Sandra 2003 running under Windows 98SE.  Therefore, I tried it on another PC with Windows ME and it worked fine on that.  However, I uninstalled 2003 on the 98 machine, put 2002 on it and it has worked fine since then.
Offline cabra
« Reply #2 on: February 15, 2005, 13:26 »
hi thanks for your reply . i am using standard 2004.windows 98se
« Reply #3 on: February 15, 2005, 13:38 »
Do you know which, if any device isnt working  :?:
Have you looked in Device Manager to check that there are no yellow ! or ?   :?:
It may just need a driver updating or reinstalling  :?
Offline cabra
« Reply #4 on: February 15, 2005, 14:56 »
dont know of anything not working and all is ok in device manager
« Reply #5 on: February 15, 2005, 15:17 »
Hi again.
Have a look at this link.
http://zeropaid.com/bbs/showthread.php?t=18130
« Reply #6 on: February 15, 2005, 15:42 »
« Reply #7 on: February 15, 2005, 17:37 »
We, at PC Pals, of course, have a fully tested and working version of Sandra, but you can't have her - she's ours!   :P  :twisted:
Offline cabra
sandra
« Reply #8 on: February 16, 2005, 08:21 »
i now have sandra working. i replaced both .dll files which seems to have been the problem .thanks to all for your help
« Reply #9 on: February 20, 2005, 16:28 »
Quote from: "Simon"
The current user interface is Foxy!!!!!!!  :lol:
