Author Topic: Installing Firewall and Antivirus  (Read 701 times)
« on: February 15, 2005, 13:34 »
I want to install a firewall and anitvirus programme on friends machine and her C: drive is almost full.
Can I install both on E:drive.
Previous Antivirus was installed in the C: drive. :?:
« Reply #1 on: February 15, 2005, 13:42 »
yep should be fine.. just make sure you remove any previous anti virus program...i run lots of software off non c: drives when using windows so i dont see why antivirus should be a problem
you might want to clear up space on the c drive though by putting the stuff on the e: one if possible
