Author Topic: emptying cache in mozilla  (Read 1160 times)
« on: February 19, 2005, 18:27 »
g'day all
anyone know how to empty the cache in mozilla.  its easy with IE but i cant seem to find a way to do it with firefox
 :roll:
edit  having said that i cant seem to do it in IE either now.  i used to right click on the IE icon and there was an option to clear the temporary files, now i dont seem to get this option.  is this a "feature" of windows XP
« Reply #1 on: February 19, 2005, 18:54 »
Go:
Tools > Options
Then select privacy and at the bottom of the page is the cache
« Reply #2 on: February 19, 2005, 19:02 »
Many thanks   :D
Re: emptying cache in mozilla
« Reply #3 on: February 19, 2005, 19:09 »
Quote from: "daveeb"
In fact, I'm hesitating to give my thought about this one, because I think you already know it, but anyway, I'm going to do that, just in case:
In IE (XP) you can get that same box by going to:
Control panel  >  Option Internet  >  (Delet files, is just in the ceter)
Is that what you're looking for?
« Reply #4 on: February 19, 2005, 20:29 »
It sure is joudi, thanks  :D
« Reply #5 on: February 20, 2005, 13:53 »
Just to let you know dave, Mozilla Firefox has a two-click "Delete Private Data" - or words to that effect.  It clears cache, cookies, history etc in one go.
« Reply #6 on: February 20, 2005, 14:42 »
wheres that then dave  :?:
« Reply #7 on: February 20, 2005, 14:59 »
In Firefox verion 1:
Tools > Options > Privacy.  At the bottom, just above the OK button,
"Delete all information stored while browsing."
« Reply #8 on: February 20, 2005, 15:10 »
cheers dave...had just found that   :)
