Author Topic: cant run cd rom, need some help please.  (Read 1331 times)
Offline Lin
« on: February 25, 2005, 17:57 »
Help!!! I hve a problem, and cant find an answer to it by searchin through the forums.
I am trying to load a driving test theory cd rom and basically it wont let me.  I keep getting the message
16 bit windows subsystem
C:\windows\system32\autoexec.nt.
and the mesage that it is not compatiable to run msdos programmes.
Also if I try and do it from the run menu, it just says that it wont do it
Another problem is that I cant install sp2 and I noticed on one of your forums that I willhave to by april, what can i do about that?
Thanks
PS eerything else seems to be running ok, internet, emails, etc etc
« Reply #1 on: February 25, 2005, 18:10 »
Lin Hi
I believe its a corupt file in XP, I have googled 16 bit windows subsystem
C:\windows\system32\autoexec.nt.and come up with several answers.
I am not that confident myself of the fix, If it was my PC I would have done it  :roll:  but as it is someone elses its a different ball game LOL but I'm sure one of the techies will probably back me up on this.
Terry
http://support.microsoft.com/default.aspx?scid=kb;en-us;324767&Product=winxp
« Reply #2 on: February 25, 2005, 18:15 »
Also may I add that it might be a Virus / spyware problem? make sure you do some scans with adaware/ virus checker as well  :wink:
« Reply #3 on: February 25, 2005, 23:13 »
Nobody?
« Reply #4 on: February 25, 2005, 23:19 »
I think we are probably waiting for Lin to come back to us.... :)
Offline Lin
« Reply #5 on: February 25, 2005, 23:33 »
Thanks guys, tried what they said, stillwont work, any other suggestions.
Lin
Offline Lin
« Reply #6 on: February 25, 2005, 23:38 »
actually, just googled again, went to
http://www.visualtour.com/downloads/
downloaded XP.Fix.EXE, and it seems to have worked, Its just worked on an old cdrom that wouldnt work earlier so will try now on the new one.
Willbe back in a bit to let you know whether it worked properly or not.
Lin
Offline Lin
« Reply #7 on: February 26, 2005, 00:59 »
Yep it worked,  thanks.
All I have to do now is figure out how to install sp2.
Lin
« Reply #8 on: February 26, 2005, 01:01 »
Glad that you sorted that out ok, maybe SP2 will install ok now as well  :)
