Author Topic: Useful Links: Linux  (Read 17598 times)
Re: GnomeFiles.
« Reply #15 on: April 03, 2008, 07:18 »
since it is all linux apps.. for anyone who doesn't know GNOME is one of the many different desktop environments for linux... its probably the most popular but then again KDE fans would argue against me
Re: GnomeFiles.
« Reply #16 on: April 03, 2008, 08:15 »
 :oops:   Thanks Sam :cheers:
TIPS FOR LINUX EXPLORERS
« Reply #17 on: April 06, 2008, 11:48 »
http://www.brunolinux.com/
These Linux tips are meant to provide just enough
information to whet your appetite for more.
They are updated frequently and are not presented
in any particular order.
There is a site-search box at the end of this page.
bit of a random webpage but lost of content. It has some good content but I'm not sure if some of it isn't just a copy and paste job off other sites. Though note the ways they suggest doing things isn't always the best - it depends on your distribution and very much worth trying to be distribution specific (e.g. with ubuntu you can use apt to get most packages), though quite a lot of the core is the same.
Linux is Not Windows
« Reply #18 on: April 06, 2008, 19:17 »
If you've been pointed at this page, then the chances are you're a relatively new Linux user who's having some problems making the switch from Windows to Linux. This causes many problems for many people, hence this article was written. Many individual issues arise from this single problem, so the page is broken down into multiple problem areas.
http://linux.oneandoneis2.org/LNW.htm
