Author Topic: An Answer from the Mods please  (Read 1070 times)
« on: March 02, 2005, 18:43 »
Microsoft antispyware ran over night so as not to be intrusive, when I checked 1st thing this morning this is what I found, could some one please explain as I can't LOL
Terry
« Reply #1 on: March 02, 2005, 18:54 »
It's part of our plan for Global Domination, Terry.   :D
But seriously, haven't a clue, unless it doesn't like your home page being changed from MSN.  ;)
« Reply #2 on: March 02, 2005, 18:54 »
All part of our sinister plot to take over the world Hook!   :laugh:   So much for Microsoft Antispy then!!  :laugh:
« Reply #3 on: March 02, 2005, 18:58 »
umm no idea!! we dont have any software on here that could do that. after a quick check nothing is odd with our server. microsoft f*ck up? I think so. is your homepage set to the forum. it could be reading htat wrong.. plus we have cookies but thats about it. weird.
solution: turn off that stupid microsoft scanner and use a better one.
better solution: FDISK your HD, install SUSE.
ultimate solution: bomb microsoft headquaters.. muhahahahha
« Reply #4 on: March 02, 2005, 19:07 »
Hi, Hook.
My guess is that you have either SpywareBlaster or Spybot S&D on your system.  Because I never use Internet Explorer (except for when I'm feeling suicidal, couldn't give a sh1t about anything, and so I go and get some Microshaft updates) I usually have them on a PC before I actually go onto the internet.  They "lock" my IE homepage.  There must be an easy setting to unlock IE, but because I hardly ever use it I don't bother.
« Reply #5 on: March 02, 2005, 19:10 »
I only use the  IE6 browser for one site, purely because it is only configured to operate using IE. Hence I have set that site as IE homepage, so when I run "Hijack This" it shows up as a "nasty" on the log checking site.
ignore it in other words.
Offline Serenity
« Reply #6 on: March 02, 2005, 19:38 »
Well Terry, I was going to say all of the above but as its been said and you wanted an answer from a mod >>>   :pcpunch:   :wink:   :laugh:
« Reply #7 on: March 02, 2005, 21:20 »
Thanks  :roll:
« Reply #8 on: March 02, 2005, 22:21 »
I've just installed and ran it twice. Once with PC-PALS as home page, and the other not.     It took with me less than three minutes to scan all.
No !  It didn't give me the same result as you terry.    That's strange though !!!
Try to run it again, you may get a different coclusion.     8)
( Or, maybe Sam inactivated the spying software as soon as he saw your post.     :wink:    )     (Just kidding)
