Author Topic: vb..object closed!  (Read 2341 times)
Offline davypipes
vb..object closed!
« on: March 04, 2005, 14:21 »
am getting this error everytime i cancell any update i do in my form:
error "3704"
"operation not allowed when object is closed"
heres the code snippet:
Private Sub cmdcancel_Click()
'dataenv is my dataenvironment connected to a access dbse
With dataenv.rssale
.CancelUpdate
End With
End Sub
any ideas on wats wrong?
and another thing...emmm..is it a good idea to trap error numbers and use them for validation? eg:
     errornum=Err.number
     if errornum=1234567 then
     msgbox(please enter all required values)
     end if
will a different number be generated on a different machine?hence not doing the validation ?
vb..object closed!
« Reply #1 on: March 05, 2005, 19:58 »
Sorry for the delay, Davy.  Hopefully someone will be able to help you with this soon.
Offline davypipes
vb..object closed!
« Reply #2 on: March 07, 2005, 08:11 »
oooh thanks simon...its wasnt that argent!! anyway i was able(with my friends help!) to get the root of the problem!! u see i had called the wrong
table ie:
With dataenv.rssale
 'should have benn..
With dataenv.rsprofiles
...so theres the bugga, but about the error number...well i still havenmt gotten any info on the adv/disdvantages of using them.
